Happytrai1s
- May 14, 2010
- 2
Need some advice please. I have searched for similar topics on this forum and have had no luck in hitting the right search terms or I am the only one with this specific issue. I believe the former is likely the case.
I have just purchased a 2006 60HP Mercury. It runs very slow at about 3500 RPM's and has on a couple of occasions caught and taken off to what I believe is the normal WOT and run up to 5300 RPM. When it does this it is like flipping a switch where it goes between running at 3500 RPM and 5300 immediately almost as if there is an electrical issue like a no spark condition on one cylinder that corrects itself. 90% of the time it is running improperly though. It has been unused for long periods of time prior to my purchase so I assumed it was just a fuel issue. I have drained the tank, refilled with ethanol free fuel, replace the external fuel lines, primer bulb and the fuel filter (was told by the dealer there were two filters but could only find one and replaced it along with the housing). Other things I have done not related to this problem was to replace the fuel sending unit, engine oil and lower unit oil. I still have the low RPM condition. The dealer said the plugs should not be an issue so I have not even looked at them. He indicated that these engines have had coil issues and that could be to blame.
Any advice is as to what to check next would be GREATLY appreciated.
Thanks for reading....
