Hello.
Its an E25TELCOS - 1985, sorry for incorrect heading. It overheated last time it was out pretty bad and stopped pumping water (not in that order). I replaced the water pump, still did not pump. Took it to an Evinrude dealer / marina to have a professional look at it, and after they replaced the water pump determined it did not pump water, and that the compression was at 75 & 45, and that the engine was on its way out. I picked it up to look at it myself.
So, being at work and not able to take a look until tomorrow, I assume that the water jacket is clogged with crap. I intend to pull the exhaust cover off to take a look to see how much mud and stuff is in there, along with pulling the cylinder head to check the gaskets.
Not being an outboard motor head, or having much experience with them, and being very worried about it, does it sound like the culprit is going to be one or both of the things I plan on checking - or does the way the compression looks tell a more sorrowful story?
Thanks for your speculation in advance,
Geoff
Geoff
