hadaveha
- Mar 17, 2009
- 389
I keep reading everything I can about these 470's, and something Ive noticed keeps showing up, running hot. the water pump at the end of the cam seems to have its own batch of problems, with that being said would it be possable to fab up some kind of external higher volume water pump to move coolant through the engine at a higher rate dropping the operating temp of the engine. I know the engine like all engines have a perfect operating temp, and maybe you loose a little performance due to lower than perfect temp, but extending the life, and making it overall a lot more dependable would be well worth small loss in performance. Just something that Im sure someone can explain why it wouldnt be a good idea.
Thanks everyone
Thanks everyone
