Hey guys i'm trying to figure out what I should do and figured i'd get yalls opinion on this.I have a 1980 Johnson 70hp that has power tilt and trim.I'm having a problem with the trim not working right.I recently had a leak from the tilt cylinder cap and I went ahead and replaced it.Then refilled and tried to bleed system of air but could'nt do it.So before giving up I could only get the tilt ram to work right.The trim will only work right while going up and takes forever to go all the way down and half the time I can't get it too.So I gave up and took the boat out and ran it.I was still able to get on plane and was able to trim it out.2 days after one of the trim cylinders started leaking at the cap.So basically starting back at square one.I'm thinking of just pulling it apart and replacing all the seals in the tilt and trim and blowing any and all places out with air just incase I have a blockage somewhere.My question is this can you buy a complete seal kit for everything and is it even possible to rebuild these things back to full working order? I looked on ebay for other units and they're ranging from $3-800 so trying to save some money by maybe doing a rebuild myself with yalls guidance and If they're rebuildable how should I go about it?.I don't have a manual to go by and not even sure if the manual would show how to rebuild them.Any help on this would be great.Thanks,Ron
