Hi.
I have a 67 1000 merc 6cyl.
I i put the motor on the boat and on the first run it seemed to rev out with full throttle and the prop not giving it all and at slow speed push along.
I did research and it says spun hub, i had the hub replaced and it all fixed up like new, it put on the motor earlier and tried again.... grrrr same problem.
I did read somewhere it might be a thrust bearing problem. could this be true, i tried to remove the thrust bearing but its well on the shaft and not moving anywhere.
My question is should this thrust bearing be loose so it can push against the rubber on the prop to cause compression of the rubber or is this just rubbish and another problem?
thanks
thanks
