Hey folks,
New to boat wiring, and I notice that my boat has a green wire form the fuel sending unit that attaches directly to the boat just under the gas cap mount. From the reading I've done there shouldn't be any grounds to the boat since that could allow electrical current into the alumunim hull and cause a galvanic reaction with the water.
Is this correct?
The sending unit was wired with two other wires to the gauge. Three wires in total.
Should I simply remove the offending wire?
Leave it as is?
Route it somewhere else?
Thanks!:joyous:
Is this correct?
Leave it as is?
Thanks!:joyous:
