Albacore Fever
- Aug 1, 2012
- 12
Hello all: I have a 1995 wellcraft with a 4.3 L vortec V-6 engine with the GX outdrive I'm having a overheating problem, seems like its not picking up prime on the outdrive, when I put the muffs on it seem to work but I had it fail to pickup while on the water, even had it not pump with a loose fitting muffs I had, just seems like it losses prime at times. the impeller was checked and found good a few weeks back, I was wondering if it may be the booster pump on the side of my engine has failed ? I do have a inclosed water system for the engine. I checked the thermostat and found it good. Don
