UK boat user
- Sep 16, 2013
- 7
Help please this is my problem and I don't see any threads that help!
Background: New engine (incl risers & manifolds) fitted 9mths ago all working, water temp solid & calorifier heating well.
Issue now:
1/ raw water cooled engine (5.7LX) comes up to temp. holds ?normal? momentarily then drops rapidly to cold, to come up to temp inside 1min, to drop back to cold ? cycle continues with oil temp increasing with running time. Calorider no longer heating. Turn engine off and turn ignition key to 1st position, water gauge registers a solid ?normal? which over time slowly drops (as it all cools).
Tried;
1/ Connected hose to raw water pump to exit overboard into bucket (filled inside 15 secs)
2/ Fitted new sender & thermostat (separately & separately tested) same fluctuating temp (as old units) perhaps with a little more range and apparent speed of cycle with new ones. Checked water temp gauge using Ohm meter (all OK ? eg working per sender resistance)
3/ Disconnected calorifier and blanked off hoses, same fluctuating water temp.
4/ With engine warm, all hoses from thermostat housing were (individually) ?flushed? into bilge with engine running. Full stream of water apparent. Also ?flushed? manifolds via drain plug into bilge, again good water flow. Re-connected calorifier hoses (individually) with same flush test. Full stream of water apparent.
5/ Took off rubber 90O elbows & exhaust ?flaps? in position (closed) did appear to open when pulled
6/ with engine warm, took out thermostat and ran engine for a few mins, steady temp very low, but more than cold, no apparent fluctuation in gauge.
Issue now:
Tried;
