I have a 1986 90 HP Mariner outboard with engine serial number A903730. I am trying to connect my instruments, Tach, Speed, Water Pressure, Gas and Oil Pressure. I have an 8 wire ignition Harness with a push key for choke. The following are the wire colors. Red (pos), Black (neg), Yellow with Red stripe, Yellow with Black stripe, Black with yellow stripe, Purple, Grey, and Tan. I also have two yellow wires coming from the Shift Lever Box. I have the standard one handle shifter forward and reverse and a button in the center to push in to increase the rpm without engaging the gears. I need help in getting a wire diagram from the ignition to the gages and also where to connect the two yellow wires from the shifter box.
