The first thing you connect & the last thing you remove is the safety chain"
^^^ you sure?
My safety chain is never tight... my boat is always secured by the winch and it holds strong. I thought the safety chain was just that--safety if the winch fails.
The winch always holds strong until it fails. Then your hopes ride with the safety chain..
^^^ you sure?
How could the chain be the first thing you connect? (Hint, that winch is there for a reason)
My safety chain coils up and has a good 12-18" of loose length before it would be tight.
your winch better be overrated past the weight of the boat..
My boat is a 1965 Aroliner Debonair, (total dry weight without motor 200lbs)
VERY few boats meet the requirement. Very few, if any, of the boats that I've owned have come with a winch that large. Winches are for pulling the boat up, which doesn't require anything close to the weight of the boat.
the wench ain't got a hook but she gots the look!
