makersmark
- May 31, 2012
- 2
Any help would be much appreciated!
Here is my problem:
My trailer has a four wire wiring harness, the left side lights on my trailer are working properly, the right right side is not working at all. I have used a a voltage tester and it will not detect any current on any of the wiring for the right side wiring. The ground seems to be good... if it was bad, I would assume I'd have left side issues as well?
On my tow vehicle, a 2005 Silverado, it came standard with a 6 connector plug and I've used a 6 wire to 4 wire adapter without incident for 2 years until recently, The adapter itself has 3 lights on it that will light up when the trailer harness is connected. One light for the right side, one for the light side, and one for the brakes or when the vehicle lights are on. On my adapter only the left side light will light up. i'm beginning to think its not a trailer lighting harness issue, and more of an issue with my trucks connector or wiring harness after I purchased a new adapter and had the same issue. Also, the lights on my truck are working fine.
Any help or recommendations would be greatly appreciated!
Thanks
Here is my problem:
Thanks
