I have a 1990 88 Johnson that runs great but will no longer shift into forward or reverse. We were on the water yesterday and were moving pretty good and all of the sudden the engine reved very high and we lost forward motion. At first i thought we lost the prop but that wasn't the issue. The shifter/throttle works fine and the linkage in the motor works fine also. I pulled the lower end plug and drained the oil and its a milky grey color which tells me water has gotten inside. Will the oil being milky cause it not to shift into forward or reverse? Any help would be greatly appreciated. Thanks.
