I have a 1995 Mercruiser Alpha-1 drive (stern drive serial # F699850) (on a 3.0LX engine), bought new, fresh water use only. Power trim hoses are original. Braided metal outer sheaths on them are breaking up (braid wire is fraying) from flexation metal fatigue, tiny prickly bits of braid wire sticking out? Rubber hoses inside are still sound, there are no fluid leaks. I was thinking I should replace them (all 4 hoses) as PM before the sharp wire bits puncture the rubber hoses. I have a marine railway at my cottage, easy to pull the boat to do this, but no trailer and so not so easy to bring boat to a mechanic. I have read elsewhere that changing them can be a nightmare due to seized fittings, access issues etc, and have also read that the wire bits are unlikely to puncture the hoses, just leave them alone, don't worry about it. Question 1: Are the 4 hoses reinforced inside (ie fabric cord in the rubber? Will they withstand chafing/puncture from the tiny outer wire braid shards if I delay making this repair? Question 2: A marine mechanic, possibly wanting to scare me, said the hydraulic oil inside is under 2,000psi pressure and will spray everywhere when I start loosening the hoses. Is this true? I don?t want to pollute the lake, which is just a few feet from the outdrive when boat is on railway. Question 3: Does it matter whether outdrive is all the way up, or down, or mid-travel, when I do this replacement? Question 4: For this Alpha-1 drive do I need to brace the lower unit or tie it up to prevent it swinging down when the hoses are removed? Question 5: For this model of Alpha-1, is it still true that I can just install the new hoses dry/empty and then simply cycle the drive up and down a few times to fill the hoses and automatically purge the air, ie no need to manually purge air or fill the lines with fluid? Question 6: Will I need to remove the mercathode block on this unit to get at the connectors? Question 7: Any other advice, please? Anything else I should be aware of? Question 8: Does anyone know what torque I should use when installing new lines to avoid over-torqueing and stripping the connectors/fittings? Thank you kindly!
