I was putting in a new head gasket on L-drive 85 hp. It was my first time, so I wasn't too sure what to do. I took the head out, put in the new gasket and got it back together. I decided to do a compression test, so I hooked up the hose to the lower unit, because I didn't want to mess up the new impeller i just installed. I took out the spark plugs, and proceeded with the compression test. I turned the engine over, and water was shooting out of the bottom cylinder, while I had the top cylinder tested.
I took it apart again, checking to see if there were any cracks inside the cylinder, or if I had installed it incorrectly. I didn't see anything. Is this normal, or could there be a crack somewhere that I just didn't see? Could it be that the new gasket needed to be broken in before I do the compression test, and some how the water leaked in? I did the compression test, right after I installed the gasket. While I was turning the engine over, the water was spraying out of cylinder number three, where the spark plug hole was.
