inside0ut
- Sep 3, 2013
- 67
So, I bought a boat. I had and have no idea what I was getting myself into.
I took it out onto the river and noticed a few things that concerned me. When I took the boat home, I started digging into the internet to find as much info as I could and came across this site. Man, is this site a wealth of info! I once knew nothing about boats. Now I know next to nothing, and, as we say at work just enough to get myself into trouble.
But I'm thinking this will be a fun ride!
My best friend and I have decided to do a full resto on her. The deck is horrible. The PO i guess decided to just lay plywood untreated on the deck and then try and contruction adsive and or screw the boards into the deck. The bow is completely rotted underneath tooo and only had one 2x4 that was rotted underneath to give support. Im am going to take the cap off in the coming days to clean everything out.
Here are some pics....
As you can see, the level of craftsmanship of who ever did the deck was...well...lacking. They didn't cut holes correctly not to mention untreated wood was used everywhere and then laid on a rotten deck.
I know this is going to be time consuming, but it will be worth it! I hope to be done by May of next year... hopefully Ill hit that goal.
I do have a few questions tho.
1. There are no motor mounts holding the engine up. Its a aq131d(found the tag!) and cantilever hung. Should I add in motor mounts?
2. How worried should I be about hull warpage when I take the cap off? I have read a differing opinion on this, that some say little to none and others say brace it really well cause it will flay out.
3. I have heard that people say barettas are know to get cracks in the hull and leak water. When I did have it in the water for two days, I didn't notice any water in it the next day...but after driving the boat around I did have to turn the bilge on to evacuate water. Could this be due to water pressure on the hull while in motion pushing through cracks or the transom may be bad? I didn't see any visible leaks.
I will be updating as the work progresses!
