I recently acquired a '59 Cutter Jet Deville powered by a 1958 Johnson Superseahorse 35 HP. I have a few questions. I know these issues may sound rather trivial, but your answers may help another novice or two. I've already had it out for a fun little ride. I'm having some confusion, however, with tilting the engine.
1) My 1959 Sterling trailer has a removable transom-saver. When I put the boat on the trailer and prepare to drive somewhere, I lower the motor onto the saver. Then I secure the bottom of the motor to the saver with a strap. QUESTION: To what position should I set my manual controls for this?
For the term MANUAL CONTROLS, I am referring to the vertically sliding lever on the front of the motor. While facing the front of the motor, you can slide it up in the vertical right groove, or lock this lever down in the short left groove (notch). What does this lever do? (Seems to control something in the tilt mechanism.) When should I use it? What position?
I am also referring to a part called the TILTING LOCK PIN on the front starboard side of the motor. (I am identifying that pin from the 1958 PARTS CATALOGUE RDS-RDSL-20 35 HP.) Do I pull the pin out when moving the engine? Do I push it in when wanting the motor to remain stationary? How is it used?
2) Are there any other parts I need to animate to move the engine up and down? Any parts to animate when locking the engine in place /trim to go boating).
3) When backing into the water, should I leave the transom saver in place until the trailer is partially submerged (to prevent the motor from scraping)? Or remove the transom and just tilt the motor up and set the small bar at the highest notch (then resetting the motor to a lower notch to go boating)?
If so, I can only adjust the engine's vertical tilt (trim) in relatively shallow water (maybe 20" or so) or the depth becomes unmanageable for walking around and titlting the motor.
4) I need a bolt. I just noticed that it's missing from the engine (but the star washer is still there). Pages 16-17 of my parts manual shows it as Item No. 81, Part No. #305168 - Screw. It looks like a bolt (not a screw) and there are no specs provided. I just have a hole. I don't know how long it should be, the threads, etc. I don't know what it holds either - looks like it has some internal function. Anybody out there able to remove their bolt and give me some info so I can get one at the hardware store? It's located on the Starboard side of the engine, in the upper left corner of the SWIVEL BRACKET.
Hoping to receive my OWNER'S MANUAL shortly.
THANKS.
THANKS.
