Re: Question on a Evinrude 200
Could have been the steep angle of the boat in respect to the oil tank sender. But easy way to tell, it is just a bit of work. There are five tan (some with color stripes) sensor wires involved. each one indicates a different fault. There are two tan wires (one on each head) that indicate overtemp. simply unplug the leads one at a time, and see if horn stops. If it is overheating, this will identify the wire that is causing your alarm. Likewise, unplug the tan wire coming from the oil tank (will have a color stripe on it), then unplug the VRO connector which contains a tan wire with stripe, then unplug the connector that comes from the vacuum switch which is right next to the VRO pump. Do these all one at a time, and you will find the offending line that is triggering the alarm. Use your head!!! Go for the most likely line first, which if I were you, would be the oil tank line. Then put your hand on each head to check for overtemp. You should be able to hold it there for a few seconds until it becomes too uncomfortable to touch. If heads are too hot, unplug the tan wire on the head to check if it is the offending circuit. One other thing, this works great in REVERSE also. To test the system to make sure the warnings are working, simply GROUND each tan wire. For each wire grounded, the alarm should sound. The 1996 and above Systems Check system is a bit different. The engine MUST BE RUNNING, for the alarms to behave properly when testing in this manner.
