Frechettem
- Aug 30, 2013
- 6
Hello all,
I recently replaced the carb's gaskets do to a leak and thoroughly cleaned the entire carb. Upon putting the carb back on and starting it up, it idled great. However, at full throttle, the boat goes 5 mph tops when it went 20 - 25 before the cleaning. I'm quite positive it is not a linkage problem and I highly doubt that there is some blockage in the carb. I have since sprayed carb cleaner through with no result. I spent a good amount of time adjusting the needles with no luck. So my question is, where are some places to start besides a cleaning and looking at the linkage. When I did the cleaning I did take out the high speed jet, which I noticed was not completely screwed in (not sure how far, 2-3 turns max). I have since tried it completely seated ans backed off a little with no better result. Not sure if that will have anything to do with it but anyway, any advice would be greatly appreciated.
