relics hunter
- Jun 11, 2010
- 118
New to evinrude and trying to bring this one back to life. I replaced the water pump the other day and I have just gotten it running for this first few times this week. The telltail seems to be slow to start running and tends to just dribble. It will spray at a 1/2 throttle or more, but not every time. I have replaced the hose and also run clear test hose off the elbow, to see the water flow. I am used to a strong telltail for the old mercury and I am not sure if this dribble at lower idle is OK. I've watched videos some, show a slow to start dribble and some show a young stud. Still adjusting the idle and throttle so I am not running it long but I am apprehensive to have a problem and not realize it. I have removed the lower end and checked that everything went together right. Water is coming out the exhaust, and prop. How much of a change is to be expected before the thermostat opens and after, in regards to water pressure?
Please advise, thanks
