Re: 470 Timing Marks
Ayuh,.... Welcome Aboard,.... Where about's in the dack's,..?? I've got a place just outside the blue line in Lewis County,....
The longer range is Btc, the shorter is after,....
Near Schroon. Bought first boat in May, took 2 years to convince wife that it was a good idea. Only able to take it out 4x this summer 'cause so much broke on it. Broke down on the lake 2 of the 4 times we went out, now I am in serious jeopardy with the wife for wasting about 6 complete weekends fixing. Boat was having the classic flood/stall/die after warming up on the lake. always popped out the carb on fast accel. Just cleaned tank out, new fuel, fuel line, fuel filter, cap rotor, (points are electronic), plugs, and rebuilt the carb. Timing is set with the light 5 degrees to the
right of the mark which I thought was BTDC, but looks like I am wrong. boat idles worse when I move timing to the left of the 0 degree mark, but I will try again now that I have rebuilt carb. Carb after rebuild no longer drips from the venturis, and I see many posts that claim carb pop is due to lean mix so I will try unscrewing the mixture screw 1/2 turn at a time on the Mercarb 2bbl. Getting a little discouraged.
