Hey I have a 89 90hp evinrude on my 17.5 ft dynasty bowrider it will push it at a steady 35mph. I'm having an issue with the Alarm horn going off. its the LONGGGGGGGGGGG beep. this usually means over heating or Fuel constriction. The tell tale is kicking out water and is cool water coming out so I don't think its over heating. you can also turn key off and crank it right back up and it goes off. well until it runs a little while longer than goes off again. Other than that engine runs like a champ. I have seen several posts about it being just the disconnected VRO causing it.
Any ideas?????
Any ideas?????
