I am looking for a bit more capable set up than what I have and don't really know what direction to go. Actually, I am trying to fill a gap.
My spinning rod is an older Berkley Pro Series One (IM6), 6', and spec'd for 1/8-3/8 lure and 4-10lb test line. I need to do some repairs to it - the rod tip got broken off, tried to fix it last night without much luck so back to the drawing board.
My bait casting rod is a 7'6" Field & Stream rated up to 3 or 4oz lure weight and 20-80lb line.
What I'm looking for is something that is able to take heavier lures than the Berkley = doesn't flex as much when casting and doesn't feel like I have a fish on when I am reeling in big spinners. Rod length that I think would be ideal is 6'6" to 7'. Based on weighing some of the lures in my tackle box the ones that are on the heavy end are about .8-1oz (med. size KB spoon, big size sonar, etc).
Target species are pike and bass, if that means much. We also do a fair amount of walleye fishing on sonars. For the size walleye, and a lot of the pike, the Berkley is fine, but its the darn lures that are way past it's range (top end on that rod is less than 1/2 oz and my sample sonar is .9oz).
When I was at the store today they had 2 rods that seemed like they fit with the 1oz lure weight - a Shakespeare Ugly Stick and a St. Croix Sport Triumph, both 7' rods with, what I would call, huge handles. Neither was what I think I'm looking for, other than they fit the spec of the lure weights.
If I could find a rod just like my Berkley but 6"-1' longer and rated for heavier lures that would be perfect (2 piece even better).
Another thought is regarding the rated lure weights. Am I over-thinking that? Should I go with a lighter lure capacity rod? I've cast both sonars and the KB spinner on the Berkley, though the rod flexes a lot it "works". A 3/4 oz top-end rated lure rod is rated for twice the weight the Berkley I have now is, so that would help out on the rod flex I'd think. Would that get me in the capacity I need even with over-shooting that top limit? Or should I really shoot for that 1oz+ range? For a real stiff/heavy rod my bait caster picks things up in the 1oz range for pike and muskie, but I just don't want to wing that thing around when I'm not throwing Suiks, giant Mepps, and spoons.
