I've been working on a friend of mines pontoon boat that we had to replace the motor on due to a cracked head. He bought a used '83 mercury 70hp motor to replace it with. We installed it and it ran fine for a couple times, then we got into this no-run issue. It will crank but not run.
I checked for fire and we didn't have fire, so checked out the stator and it seemed to be grounded out. So we pulled it off and while in there i noticed the triggers had this black gooey residue, so we decided to replace the stator AND the triggers. After installing the new items, we still had no spark. we picked up a switchbox and replaced it and still no spark.
All testing above was done with the 2 yellow wires from the stator disconnected and connected, and also the kill switch was disconnected. All grounds have been checked and cleaned. Also new spark plugs are in.
It was getting late and the battery we were testing with was running low on juice. Could a low battery not spinning the motor fast enough cause a no fire situation? There at the end it was getting to the point that it was spinning slow enough that the started would disengage.
