I'm Back Gentlemen,
I have had problems with this lemon of a motor since I bought it. It was a 2.5L 200 mercury that someone rebuilt and put a 2.4 powerhead on and switched over to EFI. Here are my problems as well as the test and parts I have already put into this. First, the motor would never turn over 4300 RPM's and would kill the motor after 10 minutes because of the stator overheating and shutting down. Neither the volt reg or stator were charging the batter. Stator and volt reg tested bad according to specs so Replaced both volt reg and stator. Fixed that problem So now the battery charges but the boat is still EXTREMELY rough out of the hole and not running good at WOT. Almost seems if it is bogging down. Once up to WOT it only gets 4500 RPMS max and is missing slightly. Took it to a mechanic and he adjusted the throttle and told me the 25P prop was incorrect for this 2.4L merc and I needed a 23p. So traded in for a 23P Tempest plus and it is still not running right. Could I have a problem with my switchboxes since it lacks power? Motor always fires right up and idles like a champ. Have 120 compression accross the board with spark on all cylinders. Any assistance with this would be helpfull as well as keep my wife off my back about this boat.
