So I went to the local lake on Saturday to burn off some old fuel and could not start, even though I had no starter related problems at all the previous several attempts over the last few weeks. :grumpy: A friend of mine tried to jump start the boat using his boat and some jumper cables and the starter motor would turn a little bit but not enough to start. So today I am troubleshooting if it is the starter or solenoid or both. I have a fully charged battery and I get 12.75 volts at the red input cable to the bottom of the solenoid from the battery. (see attached picture) And I get 12.75 volts at the small yellow wire with red stripe into the left of the solenoid only when key is turned. However, I hear no click (except choke click when using choke) and I get zero volts at the other large terminal on the solenoid with large yellow wire leading to the starter. Does this mean my solenoid is definitely bad?
Also, I went to iboats boat motor parts and they do have Sierra 18-5834 for Force 120 engines 1996-1999. I do not have an exact model number on my engine but I believe it is a late 92 to 95 Force 120 based on previous posts. Does anyone know if this Sierra solenoid would still work even though it is for different years and if not do you have any suggestions on where I might find a replacement?
Thanks in advance.
Thanks in advance.
