Golson Molson
- Sep 8, 2013
- 34
Hi new to the forum sorry if this is redundant. I have read several posts on this but haven`t found the real answer to my question I`m about to ask.
Took a new to us boat out on its second run yesterday and just couldn`t get the boat to run. The first run out, it was hard starting didn`t really warm up very well, had slight hesitation when pegging the throttle but ran fine on plane. Did a compression test when I got home on all 4 cylinders and 2 and 3 are zero.
Its a mercruiser 140 IO, Model number MCM140, serial number A344469 I suspect it is somewhere around a 1985.
Now my question: What is the major cause of head gasket failure on these engines. He had done some work to the cooling system at the beginning of August so now I suspect he may have over heated the engine.
