brim_buster
- Jul 9, 2013
- 1,204
After reading numerous post concerning the same issues I have with my Force, heres an update.
stuck a needle in the vent on carb to make sure it was clear. took carb apart to make sure the needle was seating, which it is. brand new carb from **********. everything was good internally in carb and was functioning as it should. re-installed it and pumped primer and now gas fills the carb throat and squirts out the vent hole. Fire it up and it runs for 1 to 2 minutes and dies. Same problem as before. Should I send this carb back and get a new one. I have some money tied up in this motor and would really like it to run. Thought about sending it to the shop and let them fix it, But Im pretty good at fixing these things and this motor should run like a champ and it wont
