Re: Rustoleum Neverwet
Ahh right, but since the boat is in the water (medium) and comes across air (as you move), doesn't the slicker bottom do better than a rough bottom (that would catch air) because the air wants to escape up?
I mean, I'm seeing it this way, perhaps I should read up more on it..
As you pass through water, air gets trapped underneath, the faster you go the higher percentage of air underneath. But because air wants to escape up out of water, you're constantly cycling a certain percentage of air under the hull. (slower moving= less air and more contact with water, faster moving= less contact with water, more contact with air)
But* no matter what medium you're travelling through (and never 100% air) it would come down to the friction coefficient of the paint? (that's why there's no devices to add air in front of the engine, to reduce it's drag? hehe)
Air < water, as far as friction is concerned, BUT a rough bottom boat coating will never be less than a slick coating in the areas of friction and drag...
I'm thinking of these principles without any sort of bubbler or air entrapment, think of a plain old V hull..
I know they apply principles of a bubbler to torpedos and such, but I'm curious as far as averages go.
Makes me wonder why companies even bother making hull coatings that are lower coefficients of friction if the way to go was something dull and rough (to catch air)
Under these pretenses, an old boat with a rough paint job (even broken peeling paint to trap bubbles) would preform better than a new paint job?
