Jamescenterconsole
- Mar 31, 2013
- 40
I have a 1982 80hp merc. serial#6175133. I have cleaned the carbs rebuilt the fuel pump and water pump. Compression is within ten percent. I have replaced the fuel, filter and lines to the motor. The motor idels at around 1100 and goes into gear great accepts throttle on the muffs. Put it in the water and it idels great around 1100 and goes into gear great. When I give it throttle slowly it stalls when I give it more quickly it stalls also. It stalls around 2000 rpms either way. If I leave it in nurtral it accepts throttle perfectly on muffs or on the water. From what Ive read on here it seems I may need to readjust the carbs? Any help/ideas would be great. Thanks
