Re: Switch for trolling motor
The motor will not run unless the motor itself is turned on and a given speed selected. When you step on this switch current goes to the motor and it operates at whatever speed you have selected. You need to check voltage from the input (line) side to ground and the output (load) side to ground when the switch is activated.
