I am trying to get my 1961 evinrude 40hp lark III running.
New coils, new condensers, properly gaped points, new fuel lines, rebuilt carb.
I set the top screw in the carb to 1-1/2 out and the bottom to 1 turns out.
It started right away and ran nice for about 1 minute until it sputters and died.
Moneyed up the settings trying to get it going again and will need to start over but in the mean time.
There are 2 rubber lines/hoses that are capped off with bolts inserted in the ends with clamps.
The hoses run to the front of the motor ( carb end ). See the attached photos.
One originates just behind the head and the other is below the crankcase.
Do I need these for anything or can I simply replace them with shorter newer caped off lines?
Thanks
Thanks
