I have a Merc 402 that seems to be running on only 1 cylinder until it warms up. This has happened the last 3 times out on the water.
Motor starts good and seems to run ok at low speed (it sounds kinda rough), but once you try to throttle down you only have half power (if that). Once every few minutes, you will hear the second cylinder fire (rpm picks up) and the power will come back momentarily; only to stop working seconds after. This repeats for perhaps the first 10 to 15 minutes, then it seems the second cylinder kicks in and you're pretty well good for the rest of the day. While running the motor continuously for the day, there have been two instances where you lose power while it's warm and running full throttle. This generally only last for maybe 30 seconds and doesn't come back.
All the connections are tight. Due to the intermittent nature of this problem, I'm thinking it has something to do with the ignition system. I'm not certain which cylinder isn't working - by the time I pulled the cover to pull the plug wire it started working again.
Model: Mercury 402 (2cyl, EL - Electric Start, Long-Shaft)
Serial Number: 7102322
Year: 1977
Compression: 120PSI for both Cyl #1&2
Spark: Getting spark from both plugs
Fuel: Seems good as I can run all day after warm up without trouble.
Resistance Tests
Trigger (white to brown): 819 Ohms
Stator (red to blue): 5100 Ohms
Coil #1: .2 Ohms
Coil #2: .2 Ohms
DVA Tests - Motor running on earmuffs (CDI PN: 511-9773 /w Fluke 85)
Trigger (White to GND) = .8V (changes from .6 to .8)
Trigger (Brown to GND) = 13V
Trigger (White to Brown) = 15V
***Not sure if I'm testing the trigger correctly?
Stator (Blue to GND) = 307V (drops to 245 after a few mins)
Stator (Red to GND) = 207V (drops to 183 after a few mins)
Powerpack out to Coil #1 = 208V
Powerpack out to Coil #2 = 198V
Any ideas what might be causing this? Anyone see a switchbox do anything like this?
Thanks,
Cambo
Year: 1977
Resistance Tests
Coil #1: .2 Ohms
Coil #2: .2 Ohms
Thanks,
Cambo
