1956 7.5HP AD-10M Received my new exhaust housing gasket #18-2894-9, (replaces OMC 304314) ordered from Iboats. The last time I replaced this gasket it came with one side of the gasket covered with a sticky substance. The new gasket does not have a sticky side. Do I need to use some adhesive on one side of this new gasket ? I have a product that is called "super sure tack gasket sealant'. I also have a can of Evinrude/Johnson Gasket sealing compound. Would it be advised to use this adhesive on one side of the gasket. Also, my Iboat order for one gasket came in a package with two gaskets. Is the second just a mistake or do I have to double them up ?
As always,,thank you for the expert help
Arne
Arne
