josephsiracusa
- Jun 3, 2010
- 49
1 year old starting battery dead after not using for an hour. battery load test results battery good. Alternator charges battery at 13.9 volts. Perform draw test and absoluteley nothing is drawing power while the battery selector switch is in the off position. i did run the cells low for a while and close to empty though there is no sign of rust on the plates. Cell levels are now on the full line as i added distiled water. Load test was done 3 times with battery fully charged. I am stuck any help? My problem understanding is all test result a good battery and alternator even after fully charged multimeter shows 12.6 volts even with battery switch off. Perhaps i damages the battery running the cells low, if so how does a load test result a good battery? An advice should imreplace the batery? The battery is being used with a volvo penta 225E engine on 1987 bayliner 2450....help please
