Re: Nissan 3.5A water pump replacement
Those small 2,5 & 3.5 are prone to deliver poor peeing specially at idle, if so, remove engine lateral cowling, disconnect rubber hose from crankcase and run a medium wire, needle, plastic tie wrap, W40, Carb Clean spray red cannula back and forth small water outing several times to clear the slight salt, debris clog that might have formed. Will pee much better.
Happy Boating
