rmcclure36
- Jul 24, 2013
- 7
Recently got a boat with a 1975 Mercury 850 on it and the lower crank bearing went out. Replaced the lower bearing and housing and while I had it apart replaced the rings and water baffle plate. The person we got the boat from said he had carb work done. I found that the top carb had the main jet loose in the bore and that the venturi had fell into the reed chamber. Got everything back together and have the engine running with good water flow from site port but it seems that cylinders 1 & 2 build heat (not hot) but cylinders 3 & 4 stay relatively cold. When I kill spark to 1 or 2 I see a noticeable change in idle but when I kill spark to 3 or 4 only a slight change. compression and spark good in all 4 cylinders and all seem to be getting fuel. Is this normal or could this be a carb issue that I'm dealing with?
Thanks
Thanks
