scottr2200
- Sep 19, 2011
- 5
Hello to all, I am a first time poster in this forum I have been a member for two years now, I have read a ton on here and have gained a wealth of knowledge from all of your advice and help given to others. So Thanks for all your help. If I posted this incorrectly please let me know. I have a 1989 celebrity 190 bow rider with the 470. I traded a couple jet skis for it some time ago. I have replaced a full floor, an engine mount and all interior, I started my project when I spun a rod bearing.
I had all machine work done and with the help of this site learning all the qwerks did a full rebuild. I know this motor in and out. But now after only 1 summer of use I am starting to get coolant in the oil, and some coolant burning off on start up, cam has had speedy sleeves installed on rebuild and new seals and gaskets thru out the motor. My compression readings from the front of the boat to the rear are as follows front cyl. 135 psi mid front 157 psi mid rear 160 psi and rear 120 psi.
I am not getting air bubbles in my coolant reservoir, and I do go thru coolant but only a reservoir full in 4 hrs of running. (I noticed it in the oil after this and quit running it) Is this a head gasket? or could it be something else? I re torqued the head after the first heat up but misunderstood my manual and let it cool, Now Ive learned to re torque when motor is at operating temp. I dont want to wrench anything until Ive gotten plenty of advice from the pros on here, I am going to get the pressure test kit from autozone for the cooling system But cant do it till next week. Please help, I love my boat, and Ive grown fond of this 470 just cause its different and people dont like them. I also did an alternator upgrade at rebuild that Cost me about 15 dollars for the mounting hardware, and a stainless bolt, Plus a little time on the lathe at work.
