I've searched everywhere and no one has a good explanation of tests to perform to rule out the alarm module as the culprit.
I get the Beeping at random. It usually beeps when i'm in gear, little or full throttle. Sometimes it'll just beep in neutral. It's not the constant beeping signifying an overheat issue, but the oil alarm beeping.
I've checked the following:
oil level in reservoir always full,
oil in remote tank shows decreasing oil level, implying that oil is being consumed, not to mention the big puff of blue smoke on startup,
disconnected reservoir level sensor wires and it still beeps,
disconnected the three wires from the screw junction on the starboard side of the motor and the beeping stops altogether(no power of course), disconnected just the temp sensor and it still beeps,
checked remote tank pickup filter and blew out any debris,
Any other tests to run? I'm leaning towards the alarm module since this is so random, yet constant.
I notice some oil residue from the front of the motor. Not sure exactly where it's coming from. Maybe a spill from the reservoir when I topped it off to see if the alarm went away. The oil lines don't have any oil on them, looks more like it's coming from the carbs.
I have a clymer's manual that does not detail troubleshooting very well, at least not to an outboard newbie like me.
