Fte1965
- Sep 1, 2013
- 11
Hi
I just became proud owner of a glastron miniday 500 with an evinrude 70HP VRO outboard motor. The previous owner had the boat lying around in the garden barely covered so you can imagine the state it was in when I bought it. The Evinrude was not the original motor, guess it is from the mid eighties. When I removed the motor cover I was very surprised that it still looked quite good. After transporting the boat back to my home I cleaned the boat. I tried to recharge the battery without success, so i bought a new battery. I filled up the gas tank, the oil reservoir was still ok so i did not refill it.
I am a newbie so I have to figure out the motor control box shifter. does anybody have a manual ??
I played around with it, pushed the pump in the fuel tube and the motor started, i guess when you push the ignition key you activate the electric shoke?
but after revving up the motor stops without any reason. Is this a problem with the carburators or something else ?
hope someone can point me in the right direction
