masternone1956
- Jul 5, 2013
- 17
flywheel magnets test what is it ? Started by flatsman, November 5th, 2003 02:23 PM
I just found this post and was wondering if this could be my issue. He is basically saying he was getting no spark and was wondering about week magnets he did put on a new flywheel and problem solved. His is a 1996 115 hp and mine is an old 1970 115 hp 115083d everything on mine checks out ohm wise. running a magnet across sensor I get voltage out of sensor wires but while cranking engine over there is no voltage and when I use a 1.5 volt battery across pulse pack sensor wires I spark thru coil every time. Sensor gap is set to 0.020 and still no spark. Has anyone else heard of this I understand it's rare. One more question is if my anti-reverse spring could be grounding out while cranking? Can I remove it to confirm that is not the issue without damaging anything? Looks to me like I can I?m just not sure.
Thanks in advance for your help
Don
Don
