Chinewalker
- Aug 19, 2001
- 8,902
Another post reminded me of something I see quite often. I see boats on cinder blocks - not a problem in and of itself - but with the stern blocks situated parallel to the boat. This is probably fine if the boat is only on one block, sitting low to the ground, but if you stack several, you won't have much stability side to side.<br /><br />When blocking the boat, if you're using cinder blocks, use full size blocks. Set the bow blocks perpendicular to the keel for lateral stability. Set the stern blocks at 45-degrees to the boat at the outer most possible spot on the bottom. This way the boat will be less likley to rock front to back or side to side. <br /><br />If you're not blocking it on a paved surface, place a large chunk of 3/4-inch (or thicker) plywood on the ground so that the blocks won't sink into the ground. 2-foot square should be plenty. If the ground tends to be VERY soft, then I'd look for somewhere else to park it.<br /><br />If the boat is larger than 18-foot you may want to add another stack of blocks on the keel at amidships to help support it a bit more and prevent the hull from distorting.<br /><br />I'm sure other folks have their own methods, but this has worked well for me. Work safe guys...<br /><br />- Scott
