Re: is my engine seized ?
hi all , have taken lower unit off & turns fine - managed to get piston free by hitting with a piece of wood , it looks like only the bottom piston was affected & once lubricated some more with diesel oil & cranked by hand for approx 20 mins it all loosened up to the stage it was turning very smoothly - then hooked up battery & turned over in small bursts all seems ok , the motor had been sitting for approx 3 years with minimal protection - may this be the cause as it freed relatively easy ? .so my next question is im gona put ti back together & try start it this weekend - do i need to clen out the release agent & oil i have used & if so how do i do it & any further info before i try start would be greatly appreciated , thanks
