Re: 85 stingray 3.0 fuses for gauges
The value should be stamped/engraved into the side/end of the end caps of each glass barrel fuse, if not, owners manual online somewhere perhaps?
At any rate, I would strongly reccomend that you convert them to a modern blade fuse type, glass barrel fuses are becoming harder and harder to find these days, ie if you had some go out and you swung by the nearest gas station, guess what they're not going to have!
