raven1978
- May 19, 2009
- 99
Situation, mid season my engine was apparently over heating. At idle 200 and on plane 225 ish. This was according to the temp gauge. Replaced temp gauge with brand new and still get the same reading. I have replaced this year ; impeller, thermostat, ECT sensor, water neck and gasket along with the water tube from the neck to the transom, and have had the heat exchanger rebuilt and tested. I can shoot anywhere on the engine with an IR Gun and get 145-155 F. T-stat housing 155-160 F. Exhaust manifold is cooling properly, and heat exchanger is working properly. Any idea WTF? The mechanic i work with and i are at a loss on this one. Need help to figure out if it is over heating or if this is some sort of anomaly. Oh yeah i can stick a thermometer into the coolant resovoir and get 160 ish on the coolant it self.
Engine is aq125a
Engine is aq125a
