Lazy 350 mag mpi
Crimxx
Wondering if Anyone can help I have 2001 sport craft model 3010 with twin mercruiser 350 mag mpi motors
My starboard motor doesn't produce the same power as the port motor and works very hard to get same rpms as port
And burns more fuel then port after the motor is warm oil pressure drops to 5-10 psi at idle I have had 2 mechanics look at it and they have no clue what it is it has been like this for 3 summers and the more weight in the boat the worse it gets
The port motor seams like it has to pull the other motor along which makes the boat burn more fuel then it should
I have had the props tuned and check by 2 different shops and there are no codes
Re: Lazy 350 mag mpi
Ayuh,.... Welcome Aboard,.... Was a Compression test done,..?? What were the numbers,..??
