alaskawild1
- Aug 27, 2013
- 3
I have what I am fairly certain is a 4.3 Vortec GI that I purchased not long ago. It has a 2bbl carburetor on it and here is the story. I bought it and it had just had new fuel filters put on and the fuel IS good. it started and ran great at idle. when I would get going there was some valve ping and it would backfire in the carb so thinking the timing was advanced I took it into my local over priced shop. they said the timing was right however that my plugs,cap and rotor were well past their life. after I inspected I let them go ahead. I took the boat back out and it immediately flooded. After that she ran fine with just one small hiccup and I put it back on the trailer. Yesterday when I went to take it out it simply did NOT want to fire. So I did some tests. I have spark from the coil to the cap but NONE from the cap to the plugs I have the delco ignition. I did a little reading and replaced the ignition control module under the distributor cap. still no fire. I went back and put the old cap and rotor back on today still no fire. Anyone have any other ideas on what it can be?
