I have a Maxum 2100SR w/ 320HP 4 barrel 5.7 with 1.47 ratio Alpha 1. We were running a Powertech 14.5X19P aluminum 3 blade prop, and would run 4900 top end, but was starting to get some cavitiation burn on the prop. Last weekend switched to a Solas 19P 4 blade prop expecting to gain some low end grip and maybe give up a few hundred rpm on top. With the Solas prop and exact same load in the boat it would only reach 4300 rpm, and if you were cruising around 2500 and laid the throttle open, it would accelerate about 500 rpms, then start to bog down and stop accelerating. We are going to put the 3 blade back on thei weekend and see if acts the same as early in the year to rule out other mechanical problems.
Do the Solas props typically have that much more grip that it would pull it down that far? I didnt expect it to lug it that hard going pitch for pitch like we did? Judging by this last outing, we would need to go down to a 17 P Solas prop to get rpms back up around 47-4800.
Would a Michigan or Mercury 18P 4 blade act the same way?
The blade shape did look different. The powertech had what looked like a flatter less progressive blade and more rounded and softened trailing edge. The solas appeared to be more progressive, with a straighter and sharper cut trailing edge, and 'felt' like it had more cup in it, (thats subjective.). But, Just looking at them you would guess the Solas was a lower pitch.
