stalker170
- Apr 21, 2002
- 47
I have this motor on a Stratos bass boat. It has been a unbelievable motor. Could not tell you the how many gallons of gas has been put thru this motor. I fish 18 tournaments a year. So, it owes me nothing.
Here is my issue: Last fall fishing my last tournament running up lake in the morning the motor shut off at WOT like you turned the key off. I fueled up that morning so thought I had water. Switched to the Port tank, motor ran fine. Drained the tank and thought the problem was cured.
This spring the motor did it again, shut of at WOT but seemed like when running at 55 or slower the problem went way. So I figured it was a fuel issue at WOT. Changing all the lines and decided to tear apart the tank switching valve. Sure enough found two broken o rings and one was on the top side of the plastic plate plugging the fuel hole. (Thought I had found my problem) Had to go with a manual valve because the plastic switching valve is no longer available.
Took the boat out and sure enough did it again in the morning running to my spot. Kinda dangerous because not good running 63 mph boats up your butt and the motor just shuts down. This time I checked the squeeze ball and it was hard, so all the fuel was in the carbs.
With a hard squeeze ball all the motor would do is roll over and not start. I was happy in away because I though finally I will be able to find the issue. (Electrical or fuel) Came back to the key, turned it a few times, it fired up. So I am thinking key issue. Ran the boat wiggled the key, tapped the key could not make it quite.
So, the only thing I can pin point is, when the motor is somewhat cold, first run in the morning, this happens. After I run the motor three our four miles, I can run her 63 MPH and it never misses a beat. So here I set??????????? The only thing that has been done to the motor is the VOR pump was changed in 2005, and I change the Regulator in 2011.
I do now think it is electrical. I am going to change the key. Not sure about the emergency shut down switch, I also have tapped and wiggled when running. But no problem. I think I will buy pass it also just to rule it out. But the consistent thing that happens is when the motor is warmed up, the problem goes away. Key and e stop should not know the difference. Fuel issues out side the motor, should not care. (The tanks, pick up lines and so on) All of the above should continue to happen with the motor warm or cold
Remember original power pack, Vapor pump has never been touched. Carbs have been rebuilt once. The only consistent thing I have is she just shuts off, once in a while before it shuts down it will hitch, and even if I back of the throttle, it may still hitch and then just shut down. But the problem goes away after the motor is run for a while.
Any ideas? Has anyone had this issue? If so what cured it. Power pack?????? I will do the basic things tonight, check all the grounds and for any lose wires. By pass the e-stop and try to get my hands on a new key switch.
My fish off is in two weeks, I need to get her fixed. We have no go local boat repair shops, just $60 per hour mechanics and they bolt on parts to trouble shoot the problem.
Any suggestions would be great!!!!!
