My 93' will fire for about 10 sec. then stall. This will repeat for about 10 min. or more. Then finally it will catch and run. I did a carb job, set the low speed timing to 4 degrees and the high speed to 24 degrees. Once it runs it goes great. It will start as soon as you turn the key. Any ideas as to what my problem could be?
