Re: 185BR prop selection
i have a sea ray 180 with the same 3.0L merc. The range for this engine is 17p-21p on my boat, but it should be slightly heavier then yours. I had the 21p on there when i bought it, and it ran ok, but had trouble getting up with the tube behind me. I stepped down to the 19p, and it is a world of difference. takes off fast, planes out quick, and with the extra rpm, i didnt loose much top end if any. I stayed with 3 blade props for all of them though.
Ive heard if you step up a blade, you are supposed to go down a pitch. If that is true, i would guess you are over propped.
I used a solas Amita 3 19p aluminum prop and cant be happier.
